Bullet
February 13, 2016, 11:24:06 am
Author Topic: 2009 G5 Muffler  (Read 1941 times)
DaBulletMan
  • Old School Is the Best School
2009 G5 Muffler
« on: September 20, 2009, 03:20:38 pm »
2009 G5 UCE  EFI Muffler and header pipe discolored after 2200 miles. Is this a problem with the muffler or pipe or just a normal occurance? The Header I can understand but the muffler? I realize there is a converter in it and that it will get hot but to discolor this much in a short time? It looks almost like it is rusting on the outside of the chrome. Possible warranty issue? Any help is appreciated...
« Last Edit: September 20, 2009, 03:35:04 pm by DaBulletMan »
Gotta Go New Old School or Don't Go... :{)>
Chris-G5
Re: 2009 G5 Muffler
« Reply #1 on: September 20, 2009, 04:32:39 pm »
I have about 2100 miles on my G5 and I have the blueing on the header and some on the muffler under the heat shield but not any behind the heat shield like yours. Yeah, that doesn't seem right and looks like shit. Hopefully they will replace the muffler.
Re: 2009 G5 Muffler
« Reply #2 on: September 20, 2009, 06:03:27 pm »
One of these days, Enfield is gonna discover double-walled pipes.
thefieldworker
Re: 2009 G5 Muffler
« Reply #3 on: September 20, 2009, 08:39:09 pm »
I'm at just of 2,500 miles, and I too have the same discoloration at the same points.
I figured it was normal, from my last bike with chrome pipes (my last bike had black pipes).
Philbomoog
Re: 2009 G5 Muffler
« Reply #4 on: September 21, 2009, 04:28:03 am »
I think the heat sheild is there to prevent you from being burnt by preventing the heat from the exhaust from disipating into your leg. Is it possible that this causes the other parts of the pipe to become hotter than normal as this surplus heat has to go somewhere?
Does the heat sheild cover any joints in the pipe? If these joints are not sealed properly then escaping gases could also cause discolouration.
72westie
Re: 2009 G5 Muffler
« Reply #5 on: September 21, 2009, 09:23:28 am »
On a kind of related note; Do all the new pipes with the Cat. Converter in them look like they have been stock chromed pipes that were cut open at the front and re-welded and then painted over the welds and chrome? The one we have now looks kind of cheesy to me in that aspect.  ::)
http://www.bgmotorcycle.com
t120rbullet
Re: 2009 G5 Muffler
« Reply #6 on: September 21, 2009, 11:01:58 am »
Mine's like that.
CJ
Chasfield
Re: 2009 G5 Muffler
« Reply #7 on: September 21, 2009, 11:16:36 am »
Remember, the AVL Lean Burn motor just wasn't lean enough for Eurocrat emissions doo-gooders.
Those UCE/EFI front pipes and mufflers were always going to get hotter than hot.
If you have a faired in plastic rocket type bike then you won't worry that the system has gone all colours of the rainbow. As Ace says, the answer for Bullet style everything-on-view bikes is double walled pipes.
« Last Edit: September 21, 2009, 11:22:01 am by Chasfield »
2001 500 Bullet Deluxe
1Blackwolf1
Re: 2009 G5 Muffler
« Reply #8 on: September 21, 2009, 04:38:54 pm »
  Suppose you could by new pipes and have them sent out to be ceramic lined to help dissipate the heat, that would also cure the problem forever.  But double wall is the best solution.  The Vance and Hines on my Kawasaki Drifter haven't turned blue in almost 10,000 miles.  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
mark
Re: 2009 G5 Muffler
« Reply #9 on: September 24, 2009, 08:15:57 am »
Hi guys,
my header and muffler pipes went blue/yellow after about about 1000 miles or so.
I wasn't too keen on it at first.
But after 4000 miles the pipes have gone a real dark blue and I think makes the bike look better.
Royal Enfield Bullet efi.
rolex explorer,datejust,airking.
omega seamaster,speedmaster,constellation,dynamic.
exiledcarper
Re: 2009 G5 Muffler
« Reply #10 on: September 24, 2009, 06:31:17 pm »
Is there any way to enrichen the fuel/air mix to the correct levels for the motor, thus eliminating this problem?  I bet the home market modles don't suffer from that crap.
