The bike was dirty, the right blinker stopped working, a new vibration had developed at high rpms, and the gear and primary oil were due to be changed.
I did a good job cleaning it up, found a loose mirror, loose blinker, and loose distributor cover, cleaned everything, tightened it all up, lubed the chain, replaced the oils, fixed the blinker. It was still vibrating, torqued the head and tightened the valve covers, now everything is as it should be. I swear it is pulling stronger than it was when it was dirty, and once again people are yelling "nice bike" as I ride by.
Nothing was hard, but I just needed that quality time with the bike. Now I resent the time I am not riding.
-Rick
