Ok thanks. I've seen that thread and a lot of the others. None seem to cover my problem exactly.
I have had the cover open that goes over the clutch linkage and I do have the newer style bracket. Everything looks good in there.
What do you guys think about adding another bearing at the end of the actuator rod, doubling them up, to add adjustment?
I think I need to pull the trans and clutch cases....
