To start I would replace the cable and see if that remedies the situation.. If it does not I would pull the trans cover and check the actuator assembly for fatigue and or fractures. If you get the thing too much out of wack and then try to use it you can breaks some of the bits in there.
I would also open the primary up and look at the clutch assembly and make sure everything is good in there.. All in all its a fairly simple system, you just gotta take er apart and figure out what bit is not right..
I pulled the cable already and it is the exact same length as the replacement that came with the bike and looks to be in perfect condition. So I put it back in. Should I not have?
I will crack the cases tomorrow. Just hoping I wouldn't have to....
this could be a riding habit thing. These clutches and cables are not meant to be held for an extended time. It is easier to go to neutral b4 you stop.... Do not hold the clutch very long at all as the cable is likely to stretch and then your adjustment is gone.
- Mike
I really don't believe I hold the handle unreasonably long at all, except for when it is out of adjustment and won't go into neutral obviously. I almost always put it into neutral while still rolling into a stop, unless I know the stop will be of short duration.
I did however acquire this bike from the original owner, a friend of mine, when it had about 2700 or so on it. Could this be from prior riding habits even though I have adjusted it since?
I'd back off 1/2 turn on the clutch adjuster screw, then tighten the locknut. Then check the cable, especially at the ball-end inside the gearcase.
Wouldn't this only back out the adjustment further?
Thanks guys!
