EFI Clubman
February 12, 2016, 03:04:03 pm
Author Topic: UH OH help C5 Oil Change!!!  (Read 1175 times)
reuter
« on: September 09, 2009, 09:56:39 pm »
When i was removing the oil filter front plate it kicked a bit knocking the washer and the small oring loose in the casement. what came first? I don't know. does it go oring washer then the cover or does it go washer oring on the post then thread it through the other filter elements. WTF not a single schematic or drawing description about this any where..
Who has done it i need a hand
thanks
r
Re: UH OH help C5 Oil Change!!!
« Reply #1 on: September 09, 2009, 10:59:41 pm »
Hello Reuter:
I have attached several pictures of oil change / filter for UCE in another thread called "UCE Oil change" started by Gashousegorilla just a few days back.  Check it out.
