Well -
One wimpy stroke on the kickstart after priming with several strokes using the decomp. Turned the key on, started to move the kicker... and found I was a few degrees before TDC instead of after... kicked back and jammed the sprague.
I was going to remove it before it failed as I've only used the e-start half a dozen times - now I gotta.
Seems the clutch assembly is jammed solid (inner and outer gears rotate together). Problem is, the outer gear is jammed half a tooth off - and perfectly blocks the inner gear (the starter gear) on the crank sprocket.
I'm thinking I need to put a good whack on the outer gear to break it loose, or, at least, make it line it up with the inner gear to be able to slide the crank sprocket off.
Am I correct that the clockwise rotation of the crank when it kicked back is what jammed the sprague? If correct, I think I need to whack the inner gear in a counter-clockwise direction to break it loose...
Starter gears and motor are staying off. Gonna plug the starter hole with a JB weld patch. Going to 18-tooth sprocket since I'll have the inner primary off.
Several days of rain forecast here... should be done by the time it dries out
Mike and Stumpy in Michigan
