OK,I may have discovered sex here,maybe everyone else knows about this.Or perhaps mite not approve for some reason I am unaware of.But....shifting gears was getting worse by the ride so took the left hand gizmo apart and found worn out bore in the splined lever to the shifter shaft that goes accross to the trans.Not the splined end.Could of welded and re bored but decided to bore just behind orriginal hole to try to shorten the thro.Shifting is absolutely transformed.Partly because it is not sloppy but it takes far less movement to change gears.It is now as good as most as far as lever travel,and seems actually to work better,period.Time will tell.If I have any trouble will post.
