after car washing
May 26, 2016, 09:41:28 am
Author Topic: Tax disc placement?  (Read 2693 times)
csbdr
Tax disc placement?
« on: July 30, 2009, 07:52:56 pm »
I bought one of those repro tax discs and holder  (I know, I know, but I like it)  Anyway, has anyone else put one on?  They are supposed to be mounted on the left side, near the bars, but I'm having a hard time finding a spot.  Any suggestions?
hoppyre
  • 06 Bullet Sixty-5. 09 Suzuki Tu250x
Re: Tax disc placement?
« Reply #1 on: July 31, 2009, 06:30:47 am »
  I mounted mine on the left fork leg where the center fender brace is bolted. used the top bolt. If you have a disc brake up front, it may not fit.
soulforge
« Reply #2 on: August 13, 2009, 02:24:34 am »
Did mine here.
Only bought the holder. Printed the paper part.
You need to make sure the paper part is thick or water will go in on a rainy day.
Royal Enfield Distributor in Korea
Belstaff Distributor in Korea
Barbour International Distributor in Korea
Former Chairman of REOCK (RE Owner's Club Korea)
2008 American Deluxe with AVL engine
1994 Triumph Bonneville
1983 Harley Davidson Electra Glide
1969 Indian Chief
PartsMan
  • I Eat Breathe & Sleep R.E. PARTS!
« Reply #3 on: August 17, 2009, 05:44:59 pm »
I love the tires! What brand are they?
Tim
th@classicmotorworks.com
soulforge
« Reply #4 on: August 17, 2009, 07:01:12 pm »
They are Maxxis, a Taiwanese brand.
Here is the URL;
http://www.maxxis.com/MotorcycleATV/Street/Classic-M6011-Front.aspx
Mind you though, Whitewall is not available in all sizes!
1969 Indian Chief
Lahti35
  • Currently Enfield-less!
  • The Department of Redundancy Deptartment.
« Reply #5 on: September 17, 2009, 05:25:56 pm »
No shame man! Bullets are all about what YOU like! I like the tax disc thingy too. Mines on the front fender bracket also as i have electric start and the tumor projection won't allow it to be mounted where i want. Soooo until i do the KS only conversion the front fender bracket is where it stays!
'03 Ex-Electric start 500....gone but not forgotten...
I'm a fuel injected suicide machine. I am the rocker, I am the roller, I am the out-of-controller!
The_Rigger
« Reply #6 on: May 12, 2012, 03:21:59 pm »
UK residents please check me on this, but I believe the tax disc was "traditionally" supposed to be mounted on the kerb side of the vehicle so that the Authorities-Having-Jurisdiction could more easily see whether or not you had paid your road-use taxes for the year. That's where I'll be mounting the replica tax disc on Fiona, once it arrives.
(of course, the question now becomes: kerb side for the US or for the UK?)
-Dave
2012 C5 Special
john hut
  • John Hut
  • EFI Bulleteer
« Reply #7 on: May 15, 2012, 04:00:29 pm »
The tax disks are still used in the U.K. As you say they are fitted kerb side as standard which is left side(sitting on bike) and was fitted onto the same bolt where the horn is fitted,I turned the horn sideways to match the holder.This is the only picture I have of this side at the moment..hope it helps
           John hut..
John Electra Deluxe Efi
Jinx
  • Here we go again!
« Reply #8 on: May 20, 2012, 07:37:13 am »
FYI I have the holder and if you don't cut a spacer the same size as the disc outta' gasket material they will let water in. Seems the cover  doesn't screw down tight enough. Bought mine yrs ago. Dated 1956. Really messes with peoples heads. ???
What doesn't kill you only makes you stronger.
2 ways to get to the top of a tree. Sit on an acorn or start climbing!
2008 RE Classic Deluxe
1990 HD FXST-C
1970 HD XLCH
1942 HD WLA
& probably enough parts lying around to make another bike. LOL!
