What IS redline on a Bullet, anyway?
I don't know if there's any "officially stated" redline that's ever actually been published, that I know of.
However, I think it's generally considered to be about 5200 rpm. on an Iron Barrel 500, and a bit higher on the AVL which is probably around 5400 rpm.
According to the Pomeroy Dictum regarding piston speeds vs engine reliability and longevity, the rpms should be kept under 4300rpm as a general practice, but some occasional revving above that is permitted within reason.
Since 4300 in top gear would be putting us at nearly 70mph in our Bullets, we generally would have no problem observing Pomeroy in most of our typical riding, as long as we don't get crazy with the acceleration revving in the lower gears.
Some people consider the Pomeroy Dictum to be dated, but most road cars today still fall within Pomeroy's limits, and our engines are also dated in design, and it's probably not a bad idea to observe Pomeroy unless you have some particular need to go fast and recognize that it may reduce engine longevity over the long term.
