2006 Electra
May 06, 2016, 07:29:16 pm
Author Topic: How to adjust the neutral finder  (Read 2584 times)
Spitting Bull
« on: October 16, 2007, 02:12:52 pm »
The stop beneath the neutral-finder lever is an eccentric rod with a bolt holding it in position.
Park the bike with some "packing" under the centre-stand, so that the rear-wheel is free to rotate. Loosen the bolt holding the eccentric, turn it so that the "big-side" is down. Now start the engine and engage second gear. Slowly pull the neutral-finder down till it slips out of gear. Turn the eccentric to stop the lever at that position. Tighten the bolt.
Tom
dewjantim
Re: How to adjust the neutral finder
« Reply #1 on: October 19, 2007, 03:46:48 pm »
When mine slips out of adjustment I put it in neutral and adjust the lever all the way down....Dew.
