Author Topic: rust repairers needed  (Read 4229 times)
jonapplegate
on: June 23, 2009, 06:29:52 am
Hello all. I know all of you keep your bikes in pristine condition at all times and never have dealt with this problem but maybe you know "someone else" who has. How do you go about fixing up minor surface rust? Whats the best way? Mostly chrome that needs a good going over and then getting sealed up good. Thanks for your replies.
Reply #1 on: June 23, 2009, 06:59:57 am
 DuPont #7 chrome polish. In worse cases, four-ought (0000) steel wool. Works for me on plated bits. Followed by the clear coat of your choice.  I hear many good things about  a POR-15 clear coat but have not yet tried it.
Geirskogul
Reply #2 on: June 23, 2009, 07:08:38 am
Wool, then chrome polish (7 or 9), then mother's mag and aluminum polish (works wonders), then finer chrome polish if desired.
jonapplegate
Reply #3 on: June 23, 2009, 07:21:53 am
Dumb question maybe but where do I find that fine of steel wool? I haven't needed any in many, many years and haven't seen it around.
Reply #4 on: June 23, 2009, 07:36:52 am
My local TruValue Hardware store has it in stock.
 If you have trouble finding it, shoot me a PM
Cabo Cruz
  • Papa Juan
Reply #5 on: June 23, 2009, 09:11:43 pm
Br. Apple, you have received excellent input from our other brothers.  I'll simply add that you might wish to frequently soak the steel wool in oil (30W, say) as you rub off the rust.
Papa Juan
REA:    Member No. 119
UncleErnie
Reply #6 on: June 23, 2009, 09:21:58 pm
I've always heard one should use a brass or aluminium wool, as steel wool leaves bits behind that rust, also.
For bad rust, I use sandpaper of varying coarsness, and/or the various creams with terrycloth.  Buffing wheels are good, but hard to get in tight places.
Run what ya brung
1Blackwolf1
Reply #7 on: June 23, 2009, 09:30:22 pm
  Above all DO NOT use any thing that contains soap such as an SOS pad it will scratch the surface of what you are trying to de-rust/corrode, also don't use Naval Jelly, it's acid base will remove chrome.  Flitz also makes an excellent rust reomver polish.  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
c1skout
Reply #8 on: June 23, 2009, 10:09:59 pm
Nev-R-Dull applied vigorously will take off small bits of rust.
geoffbaker
Reply #9 on: June 23, 2009, 10:32:56 pm
If you go to any woodworker's tool store they should have it in grades up to ultra fine #000...
redcat
Reply #10 on: June 23, 2009, 10:54:22 pm
You might try Bronze wool as the steel wool can leave tiny particles that can oxidize and stain with only a slight bit of moisture if you don't get them all off. It also comes in fine,med.and course.
Watch out for the guy behind the guy in front of you
plane95302
Reply #11 on: June 23, 2009, 11:19:26 pm
I 2nd the Flitz suggestion. It's what I use to clean SS dive knives.
stevel
Reply #12 on: June 24, 2009, 02:03:16 am
I used silver foil and coca-cola on my rear chrome guard, which had a lot of surface rust. Scunch up the foil into a ball, dip it in the coca-cola and away you go. The theory is that the foil is very soft & will not scratch, and who knows what's in the cc but there is come effective ingredient.
I got the tip off the internet, and yes - it works. I think I reverted to steel wool at one stage (still using the coca cola) and that was just as effective.
Steve
SRL790
  • 1954 350
Reply #13 on: June 24, 2009, 02:56:39 am
I've had good results with a plain old Brillo Pad.  Buddy of mine says make sure its a Brillo (not SOS or store brand).
Andy Wiltshire
Reply #14 on: June 24, 2009, 06:08:44 am
Steve
Ascorbic acid is the rust eater in Coca-Cola.
 I have seen it used to free frozen 289 Ford pistons. Removed all of the aluminum oxide and rust.
