Listen to Vince. I didn't and should have. I have the K-70 on the front, and the K-81 on the back. They are both fine tires, but the K-81 is a bit wide for the stern there. Jammed some air into it quick and dirty a few days ago, (wanted to get on the road), didn't check the pressure, and found later the overinflated tire had been rubbing the left side swingarm, just a bit. Not much clearance there, especially if you pick up a pebble or lots of mud.
Got a flat with that same K-81 last summer, but had the tire underinflated; apparently pinched the tube and,,blammo!!! Bottom line, check your pressures, always.
