Right shift kit mod.
22 Guests, 2 Users
Ice, wildbill
February 09, 2016, 12:13:33 am
Author Topic: lowering rear suspention  (Read 1372 times)
dogbone
« on: June 06, 2009, 09:05:55 am »
The shocks are 12" long on my 99 Bullet,  Will shorter shocks:
lower the rr suspension
affect the cornering
99 Enfield Bullet 535
Vince
Re: lowering rear suspention
« Reply #1 on: June 06, 2009, 01:10:46 pm »
     Shorter shocks will have several effects. With the rear end lower the front will be a little more kicked out. With this change in rake and trail the handling may be a little more stable at high speed, but a little more awkward at low speed. Cornering clearance will be adversely affected also. You will scrape things sooner and harder in corners. The shorter travel will provide a harsh ride especially with an extra load such as a passenger.
     If you are trying to reach the ground easier, a solo saddle with the short, or even no springs will lower seating 1-3 inches with no adverse effect on the bike.
r80rt
  • C5 Pilot
« Reply #2 on: June 07, 2009, 09:43:05 am »
I put 1" shorter rear shocks on my Bonnie, if it affected the handling it wasn't noticeable.
Iron Butt Association
Geirskogul
« Reply #3 on: June 16, 2009, 09:46:01 pm »
Speaking of shocks - the snidal manual (my owner's manual hasn't arrived yet) says you can adjust the preload, but I really don't know how.  Any way to do that?  It says, for one rider, the lowest setting is appropriate, but it comes on the third setting from the factory
cyrusb
  • Kept man
« Reply #4 on: June 18, 2009, 08:35:41 am »
Your brake rod will rub on the lower right rear strut mount. I changed to the softer springs and got a lower ride height and a much more comfortable ride.
