Love your saying, Rideon! I wave to Harleys but they often don't wave back... They must be ashamed seeing such a nice bike as a Royal Enfield! Ha!
I've got a question though... My '08 Classic seems to use what I think is a fair amount of oil (it has the OEM breather setup), and the center stand appears to have oil running down it somehow as the rug on which the bike sits in the garage (they formerly used the garage as a place for their pool table and had a rug installed on the floor--so I left it there--too much bother to try to rip out--besides, an RE deserves a fine place to sit! ). After reading everyone's entries, I'm beginning to wonder if I'm losing oil out the breather. Could that be possible? Seems so from what everyone is saying.
Thanks guys for any wisdom you may have on the subject.
P.S. Ace.cafe -- love your informative entries and responses! And I suspect you gotta be a 'colonial' as I noticed you got your tubing from Lowe's -- I don't think they're in Britain, are they?
Yes, I'm a "colonial"!
You could be leaking oil from a full catch can, which would indicate oil losses out the breather into the catch tank. But that's just a guess.
If you haven't re-routed your breather, it's time to do it.
If you want to retain the catch can system, you can simply take off the main breahter hose that goes from the oil tank to the catch can.
Then put it back on with the ends swapped, so that the molded bend in the hose is up at the catch tank, instead of on the oil tank end.
Route this hose over the frame member, instead of under the frame member. The stock routing of the hose under the frame member is not good.
This way, the sharp bend is removed from the area over the oil tank, and provides a certain amount of free-er breathing flow that way, so it is less likely to get clogged with "mayonnaise". And routing it over the frame member gives it a modicum of high-routing, so that the "standpipe" function is at least partially achieved.
That generally helps. And it doesn't cost a dime to do.
If you want to delete the catch can system, then run a 3/8" I.D. hose from the breather outlet on the oil tank, up high near the seat(as directly vertical as is feasible) and then route the hose to your preferred exit location, and put a duckbill on the end.
I like to run it to the rear of the bike, and exit it with a duckbill near the license plate.
Cap all the other hose barbs off.
Done.
