Well, I didn't get round to the float as I have been cleaning the carb out with the little time I had to ensure that the Jets were clean but alas to no avail.
Well I sat down to the float bowl today with the Electra Service Manual. I have read and reread but cannot work out how to measure this properly Please see below:
https://sites.google.com/site/23hpre/_/rsrc/1244710368681/Home/Float.jpgI think I have a problem with the float as when inverted the float point Y is resting on the base of the carb below. I think that this would mean that the carb float is at its highest point and possibly causing overlyrich situation.
Where I am really confused is with how to measure the float height. As the Service Manual states the carb should be inverted and the measurement should be from the mixing chamber body face to the top of the float and this should measure 17.1mm
Elsewhere in the manual it coincides with rick stating the centre of the mixing chamber to the top of the float.
Now the more I look the more confused I am getting and starting to question what is the top and the bottom of the float (when inverted) and what is the centre of the mixing chamber and what is the mixing chamber body face!!! Really driving me mad now.
Anyone care to assist before I toss this out of the window...
Any suggestions on how to bend the tongue without breaking it would be appreciated (I'm a bit of a disaster)
-Edit-
Well stuff the Measurements. After a week of not starting, trying everything all I had to do was to bend the float tongue a bit. I say a bit as that's how I measured it... As it was resting against the base it could only bend one way (less fuel - leaner) so about 4-5mm to give her some clearance. Fitted her. Primed her. First kick a slight backfire. Not good. Choke out. Primed. Second kick - WHAM grrrrrrrrrrrr thump thump yepeeeeee
Drove her around the garage a bit then turned her off. Kick grrrrrrrr - excellent she started again. The great thing is I took her to work this afternoon and turned her off. Tried to kick her and she started again! When HOT!!!
Now I know I'm jumping to conclusions here as I have yet to test her on the open road, see if she overheats, check if she starts when hot always, but she started so I am one step better than I was last week.
