Take it from someone who has jetted 2 smokes off road bikes for decades.
You gotta remember the needle when jetting. This controls the mixture from 1/8 throttle to 3/4.
On a lot of older KTM, they ALWAYS had a burble at 1/8 throttle, where the pilot ended and the needle/slide took over.
The cure for this was to install a bigger cutaway slide, (stock was 6.5 you tossed that in favor of a 7).
This is my 3rd R.E. and I never had to replace the slide
, just set the needle position.
I like to have my mixture screw at @ 1 1/2 turns out, this way I have a little mixing room for temp., fuel, etc.
You can go CRAZY
and broke dropping in brass.
I got a set of brass from our host here that should cover all your mixing needs.
But, if'n you need brass, take a jet to a bike shop and they should be able to match it up.
Do one step, run it, then another.
Always make a record of what you did. I write on the bowl the jet sizes, so I know where I'm at.
Make sure you filter is clean, and if you oiled it, all the excess oil is pulled off it.
Good luck and let us know the final settings.
I'm running a free-er flowing exhaust, (A slip on that was a Harley 1200, opened the bottom of the air box, (I have a military model), so I think I'm breathing easier.
I ended up 2 steps richer on the pilot, (I can't remember the #)
, a 120 main, 1 step richer on the needle.
It starts nice, pulls strong, and my plug is a good tan.
Just this old guys thoughts!
Joe
If it's running great, I didn't fix it!
