Hi Blackwolf.
I just want to be clear you are talking about this carb?
http://store.royalenfieldusa.com/30mm-performance-carburetorI am currently trying to dial in it on my iron barrel military. Do you also have an iron barrel?
There are some things to keep in mind. First off is if you are ordering it from the CMW parts catalogue the description says that it comes with a 140 main and 19 pilot. The 19 pilot is a misprint. It is really a 38 pilot. I think some people here think that they are running a 19 pilot when really they are running a 38. (I have this info from the manufacturer of the carb) The extra supplied 25 pilot would be leaning things out at idle if you went that way. I found that my bike did not like the 25 at all. The 38 seems to work really well for idle, using the choke for a 1st kick start.
The other thing to keep in mind in terms of jets is that unlike other carbs and carb theory 101 the main jet has a great effect on the lower throttle openings. (I also have this info from the manufacturer of the carb) At a 140 main I think it is way too rich. I started with the carb out of the box. 140 main, 38 pilot (at the time I thought it was a 19) and needle in middle position. As I started to reach the higher RPM in 1st and 2nd gear there would be a huge hesitation, enough that I just turned around and headed back to the garage.
I installed the leanest jet supplied, the 132 and leaned the needle into the second clip position from the top. That improved things dramatically with a slight hesitation in the same spot. However when I've got into a situation with some long idling and prolonged 1st and 2nd gear movement I would start to get popping in my exhaust when I would engage the throttle and have to pull over and let things cool down. Just to see I leaned the needle to the top clip position. It eliminated the flat spots but worsened the popping problem. I then richened it up putting the clip in the middle position and hesitation at the top of 1st and 2nd got a lot worse and I turned her around and headed back to the garage.
This now leads me to believe that the 132 main is still too rich. I'm waiting on delivery of 130, 127 and 125 mains. My next move will be to drop the main by one step and keep the needle position in the middle and err on the side of rich with the needle position to eliminate a lean condition at the smallest of throttle openings.
The supplied blots are in my opinion too short. If you screw them all the way into the head then put on the carb with the gasket, what's left is barely a couple of threads for the nut to grab onto and that's without using the supplied washer. I went to home depot and got a couple of longer M8 - 1.5 bolts, sawed the heads off and am much more confident in how much more there is to grab onto. The supplied bolts also had a hard time screwing into the head. Not so with the blots from home depot. You do not need to use the O ring.
I do have high hopes for this carb as start up is great, idle is great and when I was close with a very lean needle position perhaps compensating for a too rich jet, things really ran well with some real punch in 3rd and 4th gear. I just have to eliminate the lean condition at very small throttle as New York City is unforgiving in its stop and go traffic.
I should say that I have the classic 50's exhaust, K&N 28mm pancake air filter and am close to sea level in the New York area.
What trouble did you have with your stock carb?
Here are some of the answers I received to a very long email I wrote to JRC, makers of the carb. I'll spare you all the email I wrote them.
Answers -
On this carburetor the main has very large affect at 1/4- and up throttle. It is a bit different than a conventional round slide carburetor in that respect.
The main jet has a very broad affect on the midrange unlike most carburetors. I think you will find it may help to work down in size.
The O ring is an additional seal on the inlet manifold, it is a redundant feature and isn't required for proper used of the Carburetor.
