Hi all,
This past few days has been interesting as I came squarely up to the problem of torquing my head bolts. I wasn't entirely satisfied with my torque wrench (TW), and, it turns out, with good reason as I am at the lower limit of accuracy and found it is just to large a TW to give good results. It's range is from 30 to 150 foot pounds and it is just too big. So I got out Pete Snidal's manual and started looking at things more closely. It seems that the head nuts should be torqued to 24 foot/ pounds, or below what my TW will do.
Then I started to look at other torque values that Pete has given, and even went further and surfed the net a bit to find out more about the subject. It seems that many mechanics have half a dozen or even more TWs in various ranges and types. Interesting, though more inconvenient, the old beam type are the most reliable and others should be calibrated by a professional calibrating service at intervals. If one drops his modern TW it is likely to be useless and other rough usage has a similar effect. The cost of recalibration is high and the TW must be sent off to get it done.
So there is discussion going on, with people like myself (infrequent users), saying that if one is careful and doesn't abuse and turns the torque adjuster down to just above zero, there shouldn't be a problem. Anyway, if it is close, the main thing is that it will give even torquing of, like, head bolts or nuts.
Then I got further into Pete's manual and found values for all sorts of bolts and wondered if anyone really used a torque wrench for these. I did go down and test a few of the cover bolts (gear and timing) with a screw driver and found them to be 'falling out' loose. Remembered too an Indian mechanic guru on Enfields who recommends just getting a feel for the bolt tightening and just tighten to a point where there is some feeling of pull to the threads. This seems quite correct. And I remembered clamp's description of his mechanics teacher disparaging use of a torque wrench, saying a good mechanic should be able to do it by feel, and if not, get out of the game.
On the various threads there seem to be some who use their TWs every day, multiple times, and there was one bike mechanic who claimed the need for a certain type of TW for a certain bolt on the bikes he works on.
Well, I grew up at a time when we just begged or borrowed (or rented) a TW to do the head bolts and that was it. I can remember that I broke a few until I learned the art of not tightening too much, and I get the feeling that if I don't use a TW, I have a better feel for the bolts and an idea that they in turn feel a bit more comfortable in being snugged down but not too snug. I get the feeling too that a mechanical contrivance like a TW depersonalizes the process.
I suppose the question here is, do you torque much or very little? And if you tend to torque, which bolts in particular do you do so to. Just trying to get a feeling of what Enfield mechanics are about. What sort of TW do you prefer? How often does it get used? And, do you send it often for recalibration, something pretty impossible for me to consider.
Well I managed to find a good deal on a TW of the so-called clicker type, then went ahead and bought two of the beam type, one for low torque values, one higher, and that one I can used to test the clicker against - sort of a home brew method of calibration.. And I have my old 30 to 150 ft/pound clicker in case i need to get serious about some of the bigger ones. Probably I will rarely use any of them! But I suppose that if I m going to pretend to be a bike mechanic, I should have the proper tools to complete the image.
