Finished paint
31 Guests, 2 Users
iRideRoyalnVA, Arizoni
May 27, 2016, 11:11:31 pm
Author Topic: High Output Coils?  (Read 1766 times)
geichal
High Output Coils?
« on: October 02, 2007, 08:35:28 pm »
I am wondering if I can use one of those tiny high output coils (Nology?) instead of my standard Lucas coil, and if there would be any performance/reliability gain?  I'm trying to hide as much of my electrics as possible.  I'm still clinging to the points for now.
THANKS!
geichal
dogbone
Re: High Output Coils?
« Reply #1 on: October 03, 2007, 06:12:44 am »
The primary resistance must be correct. I don't know what it is, but I saw it in one of my manuals. More voltage to the plug means more current draw. Points won't last as long.
I removed the Boyer B that came with my early 99 bullet, and replaced the points. I like the reliability. Moroso or Accell have a chart of their coils primary resistance I think it was in the Summit Racing catalog
99 Enfield Bullet 535
Thumper
  • Psalm 23
  • Classic Wannabe
« Reply #2 on: October 03, 2007, 06:52:13 am »
THANKS!
geichal
Specs do have to match up. The coil needs to be compatible with a points system.
After many years and the the electronic ignitions failed on our Urals, many of us chose the less expensive route and converted back to points ignitions. (This was not difficult because the design was basically unchanged and it was a bolt-on affair with minor rewiring). When we chose to retain the coil that was designed for the electronic ignition we had to add a ballast resistor into the circuit. The ballast resistor used was a common late-60's or early-70's automotive unit available at most automotive stores. This was needed (as previously posted) to keep the points from burning up.
If you go this route, I have notes on my experience that you're welcome to review. Also, there's info on the Web. I found some BMW articles about it, as well as automotive.
You might post the question to the Hitchcock's bulletin board where it's likely you could get some very specific recommendations for compatible higher output coils.
Matt
geichal
« Reply #3 on: October 03, 2007, 07:59:04 am »
Thanks for all the info, I'm thinking that I'll order the Bosch coil from CMW as I am wanting to keep the points.
Geichal
