Author Topic: ? for Ace  (Read 3849 times)
Blltrdr
  • cycle-delic music
on: May 06, 2009, 07:31:30 pm
I just ran my breather hose to the rear fender. After reviewing the pic, should the duckbill be shortened or is this where it should be? By the way, I found it very hard to track down the same type of hose as original. I found a 3/8" I.D.X 1/2" O.D. black vinyl hose at Home Depot 10' length for $4. It was to tight for the fittings so I warmed up the ends with a heat gun (easy does it) and it slipped on like a glove. Only time will tell if this holds up, but this hose is rated for chemicals and so on.
Blltrdr
2003 Classic 500 5 spd
2009 HD FLHT Police 103 6 spd
ScooterBob
  • Yeah - I get it ....
Reply #1 on: May 06, 2009, 07:56:19 pm
That's a good lookin' job! I use the same hose on my Brit resto projects - it's almost identical to the crankcase breather hose used on the Norton bikes. So far, so good with it. I'm guessing that you'll be just fine!
Reply #2 on: May 06, 2009, 08:07:57 pm
Blltrdr,
That hose should hold up. I've been using a clear vinyl hose for over a year with no problems. If it does deteriorate over time, it's cheap to replace.
Regarding shortening the duckbill, no I don't think it should be any shorter.
In fact, depending on how stiff that duckbill hose is(I used the short one from the catch tank, so I don't know), you might want to put a stiff wire(or something) bracket near the end, so the wind doesn't blow the duckbill backward/upward and spit the oil fumes onto your nice-looking license plate holder.
I made my hose a bit longer than you did, and actually tied it to the bottom hole of my license plate with a cable tie(I know you hate them, but that's what I did). Mine sticks out about 1" straight back under the license plate.
After using this awhile, I notice that the oil fumes do leave some oil vapor deposits around the license plate area, because of the swirling turbulence behind the bike.  So, you need to wipe that area off periodically, because it gets lightly oiled.
BTW, the back end of your bike is REALLY looking GOOD!
And your breather hose installation looks great too. I just don't know about where the oil vapor fumes are going to wind up with that, so keep an eye on it, and adjust the outlet position as necessary to achieve what you want.
If the duckbill doesn't blow around, and it doesn't really get much oil deposited on the license plate holder(it WILL get some small amount on it anyway, no matter where you put the outlet, from turbulence), then you're fine the way it is.
I think it's cool to watch the duckbill opening and closing when the bike is idling, while I'm warming it up. You can actually watch it working.
« Last Edit: May 06, 2009, 08:16:35 pm by ace.cafe »
Blltrdr
  • cycle-delic music
Reply #3 on: May 06, 2009, 08:21:06 pm
Thanks for the comments and suggestions. I do value all input when it comes to formulating ideas. Maybe if I cut off 2", it would raise the duckbill up so it is tucked behind the license holder. This might ease the turbulence effect on it and also keep the duckbill hidden from the rear view (aesthetics).
Blltrdr
« Last Edit: May 06, 2009, 08:28:25 pm by Blltrdr »
Reply #4 on: May 06, 2009, 08:23:13 pm
Thanks for the comments and suggestions. I do value all input when it comes to formulating ideas. Maybe if I cut off 2", it would raise the duckbill up so it is tucked behind the license holder. This might ease the turbulence effect on it and also keep the duckbill hidden from the rear view (ascetics).
Blltrdr
It might.
Or it might be okay as it is.
You just have to ride it and see what it does, and adjust if needed.
Blltrdr
  • cycle-delic music
Reply #5 on: May 06, 2009, 08:31:27 pm
It might.
Ah ha! The wait and see approach. Sounds like sound advice to me, will do.
Blltrdr
Cabo Cruz
  • Papa Juan
Reply #6 on: May 07, 2009, 12:11:58 am
Br. B, that was a cool looking modification!  One question: Why do you keep your bike so grungy looking?   :D  (VERY CLEAN, BOSS!!!)
Papa Juan
REA:    Member No. 119
Blltrdr
  • cycle-delic music
Reply #7 on: May 07, 2009, 12:33:20 am
Well Br. Cabo I didn't see a speck of anything on yours either. We must be suffering from the same ailment, WIPERBIKEALOTIS;)
« Last Edit: May 07, 2009, 12:44:44 am by Blltrdr »
Cabo Cruz
  • Papa Juan
Reply #8 on: May 07, 2009, 04:57:57 am
Br. B, is WIPERBIKEALOTIS! a terminal disease?  Or, is it just a chronic condition affecting recovering perfectionists?  :D :D :D
Papa Juan
REA:    Member No. 119
woodboats
  • New Zealand
Reply #9 on: May 07, 2009, 05:18:41 am
Looks great!
How do you make the duckbill?
I have just lefy my hose with a round end, should I change ot to a duckbill?
Cheers
Ours: 2006 Bullet Deluxe 500
Hers: 2007 Yamaha V Star 650
His: 2007 Honda Shadow Aero 750
Blltrdr
  • cycle-delic music
Reply #10 on: May 07, 2009, 05:55:10 am
Terminal? Yes, WIPERBIKEALOTIS can be terminal if the afflicted are not kept away from cleaning products. If left unchecked this disease can morph into something completely untreatable. An intervention may be in order as a last ditch effort to save the afflicted from their perfectionistic vision. If this horrible disease cannot be kept in check God help us all.
Blltrdr  ;D
« Last Edit: May 07, 2009, 03:38:02 pm by Blltrdr »
Blltrdr
  • cycle-delic music
Reply #11 on: May 07, 2009, 05:58:38 am
Looks great!
Cheers
Purchase the duckbill from our CMW. Yes you need a valve (duckbill).
bob bezin
  • I ride therefore I am.
Reply #12 on: May 07, 2009, 04:42:44 pm
the cure for wiperbikealotis is verry verry long road trips . start out early in the morning and ride till sunset ,pitch your tent in the twilight and sleep getting up early the next morning ,preferably before sunrize, and hit the road.  continue doing this till any symptoms of wiperbikealotis  dissappear.
2015 indian chief vintage
65 500cctriumph
04 bonnie black
71 750 norton.
48 whizzer
Blltrdr
  • cycle-delic music
Reply #13 on: May 07, 2009, 04:53:18 pm
Yes Bob that is part of the recovery strategy for this affliction. Thanks for bringing it up, your doing your part in this awareness campaign.
Blltrdr
UncleErnie
Reply #14 on: May 07, 2009, 05:47:12 pm
I've heard of this duckbill thing- what is it and why would I want one, please?
Run what ya brung
