Offroading on the banks of Yamuna river. Delhi
May 30, 2016, 09:13:42 pm
Author Topic: Chain adjuster  (Read 1592 times)
UncleErnie
Chain adjuster
« on: April 27, 2009, 09:41:22 am »
How about stamping them at the factory with a scale of some kind?  Maybe a line to every other indentation and numbered 2, 4, 6, and so on.  It would sure make life easier to adjust a chain.  I'd buy a pair.
Run what ya brung
scoTTy
Re: Chain adjuster
« Reply #1 on: April 28, 2009, 09:46:27 pm »
adjust your chain equally on both sides of the axle..  keep a straight line with the front wheel//  just about but here abouts 3/ 4 inch give with your finger tip on the chain looking for loose play
1Blackwolf1
Re: Chain adjuster
« Reply #2 on: April 28, 2009, 11:13:02 pm »
  If you can find a chain alignment gauge they work pretty slick.  Saw a set of magnetic scales on e-bay for round ten bucks that look like they should work okay.  But haven't seen them in action.  Will.
Will Morrison
2007 500 Military
2000 Kawasaki Drifter 1500
2000 Victory V92SC
Many, many other toys.
The garage is full.
UncleErnie
Re: Chain adjuster
« Reply #3 on: April 30, 2009, 05:19:35 pm »
No no no- I didn't say it right.
It's like a half-shell or crescent shape with a hole for the axle- one on each side.  Along the outer edge are the indentations where the stop-tab fits into.  I was thinking it would be nice to have those indentations marked to make it easier to be sure they're the same on both sides.
I finally got the bright idea of using a puch to mark them.  That helped some.
« Last Edit: April 30, 2009, 05:21:40 pm by UncleErnie »
Run what ya brung
1Blackwolf1
Re: Chain adjuster
« Reply #4 on: May 01, 2009, 12:54:00 am »
  Okay I see now..I just used a dap of black paint before I adjusted mine last time.  Whatever helps you out is best for you.  We all develop little tricks on these.  Sort of how Brit bike maintenance is.
Will Morrison
2007 500 Military
2000 Victory V92SC
The garage is full.
pknopp
Re: Chain adjuster
« Reply #5 on: May 22, 2009, 05:53:14 pm »
 The indent markers are pretty slick and easy. I would think that you could find a set from something else that you could adapt.
2000 Dlx
