I think that's the compressor kicking in, and it's on a belt.
when it goes on there is more mechanical resistance.
with the stator and magnet,there is no physical connection.
YES there is a physical resistance. When you turn any electric item on in a car, it increases load on the alternator. An alternator works essentially like a reverse electromagnet. In an electromagnet, a wire wound around an iron object is given a charge with electricity, and the iron rod/item becomes magnetized. In an alternator (nutshell version) it's the opposite of that: the iron "object" is spun around inside the coils, and the coils PRODUCE electricity. When you move similar poled magnets near each other, they repel. That spinning iron core will repel the coils more when there is a load put on them than when there is none, so turning on something like a headlight on a motorcycle (or the headlights on an older car, 5A each at 12v) can more than double the spinning resistance. The smaller the alternator the more the resistance is raised.
That's why, in performance and hypermiling cars, people switch "off" the alternator to increase horsepower, because the alternator causes resistance to the system when it's producing power. To switch "off" the alternator they simply have a switch that disconnects it - removing the load on the alternator removes the load on the spinning serpentine system. Man if it didn't produce any load on the system then it would be free energy.
I know this isn't a car forum, but I didn't want you to have the wrong idea. Just trying to help out
This is for automobiles, but can also be read for more info:
http://www.svapowerproducts.com/html/how_much_hp_does_an_alternator.htmlA bad alternator could start to make noise if one of the coils is shorted/stator is damaged/so on and so forth but not make noise without a lot of draw. The history of the RE motorcycle points to something other than the alternator internally, like it rubbing on part of the frame, but it always COULD be the alternator itself.
