You'll need the stock manifold and gasket and intake rubber hose. They are all smaller sizes than what was on there with your 34mm carb.
If you want to use your current K&N filter, you could probably find a rubber reducing ring or adapter for it, if you are creative. If not, you can buy a new K&N for the smaller carb, or you could buy a stock airbox with the rubber connector hose for it, and the bracket, and put it totally back to stock. If you go to the stock airbox, it might be a good idea to look at the modifications for installing a K&N ring-type filter inside it. The stock filter is awfully restrictive.
You'll need correct jets for your location, which will likely be around 27.5 pilot(which is one step larger than the stock one) and about a 127.5 main jet. The exact jet sizes will depend on your elevation above sea level, and the temps you are seeing. If you use the stock restrictive filter, you might need less jet size, because you won't be pulling as much air thru it.
If you decide to hang the K&N off the carb mouth, then get some small aluminum bar stock at the hardware store and make a little strut from one of the frame studs to the filter clamp, so you can support the flying end of the intake system. That will help to save the rubber intake hose from failing early.
Piece of cake, really.
Just replace everything from the head joint out to the air filter system, and you'll have it.
