thanks, t120r
Yeah, I've been playing with that shift plate and it IS frustrating. One thing I AM going to do is that as soon (if ever!) as I get it set right, I'm going to find some way of scribing a mark on it so that it will be easier to get that "sweet spot" in future.
Good tip on the neutral finder bolt - I KNOW based on what you just wrote that I've got that on too tight!
The switch I've cleaned a couple of times. Not sure what the problem is but I defintitely am still experiencing general electrical problems so it may be related to that.
I'll adjust some more and do as you suggest with the detent screw. I'm betting that will fix it.
As I will be removing every wire in my bullet in the next week, I'll replace the whole neutral wire as well and see if that solves my problem.
You'd be amazed how many craciked wires you can find, once you start looking!
I'm replacing the wiring because I am installing motogadget's m-unit - a single solid state device that replaces every fuse, relay and flasher in the system. Additionally, I'm putting in a Boyer power box to replace the old reg/rec.
Hopefully, my wiring troubles will all be over soon...
