You are still way lean on full throttle. Try jets larger than 142, then mess with your needle.
I went through a similar situation when I was testing velocity stacks. My main jet had to be raised from 230 to 290 (amal jets), which is a huge increase and at the time the largest jet I had was a 270. I just could not believe that I'd need any jet bigger than that so i figured there was a problem with the carb/air leak, piston issue, electrics issue... etc.
