My C5
May 24, 2016, 10:49:40 am
Author Topic: 1st degree  (Read 2397 times)
dogbone
1st degree
« on: September 18, 2007, 01:45:25 pm »
Does anyone manufacture a degree wheel that can go on the alternator bolt?I The hit n miss of the manual doesn't allow ignition or cam timing with any accuracy. It's easy to remove the primary case for as many times that timing needs to be checked.
99 Enfield Bullet 535
Sam
  • Uralist & now, Bulleteer!
Re: 1st degree
« Reply #1 on: September 18, 2007, 03:39:04 pm »
degree wheels are pretty easy to find. Expect to pay $30 to $50 or so. The 0.8 mm before tdc is hardly hit & miss; it just requires some precision in measurement. That's been pretty much a standard way of setting static timing for as long as I can remember, and that's a long time.
Agreed, though, that a timing mark on the alternator would be better for checking timing at full advance where it really matters.
Re: 1st degree
« Reply #2 on: September 18, 2007, 05:23:27 pm »
Check out this degree wheel for $9.95
http://www.royalenfieldusa.com/timing-disc-p-213.html
Re: 1st degree
« Reply #3 on: September 18, 2007, 08:11:58 pm »
I've got one in bitmap I'd be glad to send you...
contact me off group-  Mike
Re: 1st degree
« Reply #4 on: September 19, 2007, 03:12:18 pm »
This came from our BulletManiac brothers across the pond at Bulletmania. I'm sure that they won't mind sharing...
- Mike
RagMan
  • Bulleteer, Uralist &
Re: 1st degree
« Reply #5 on: September 19, 2007, 05:20:02 pm »
Just ordered one today, thank you for the link.. :)
aka Indiana Bulleteer.
Jefferson County, WA
