Her Royal Majesty
36 Guests, 6 Users (1 Hidden)
oTTo, cstorckiii, gizzo, MarkF, Gesewa
May 04, 2016, 12:26:41 pm
Author Topic: Cam Cover  (Read 1688 times)
Thumper
  • Psalm 23
  • Classic Wannabe
Cam Cover
« on: September 18, 2007, 07:13:28 am »
Todays Hint:
The square cam cover with the decompression release bracket is aluminum:
Don't over-tighten it!
We'll see how well JB Weld and RTV seal it up while I await the replacement.... ;)
Matt
RagMan
  • Bulleteer, Uralist &
Re: Cam Cover
« Reply #1 on: September 18, 2007, 09:35:56 am »
It is good to know, sorry you found out the hard way, and thank you for posting the warning.
aka Indiana Bulleteer.
Jefferson County, WA
Thumper
  • Psalm 23
  • Classic Wannabe
Re: Cam Cover
« Reply #2 on: September 19, 2007, 10:58:56 am »
Well the new cam cover is on the way. My temporary fix is oil tight !  ;D
I'll make sure not to use excessive force on the new one!
....There's nothing like getting off the bike after good run and bending over to see if you've fixed the oil leak; only to find nice dry engine fins and crankcase, and drip-free drain plugs!
Sweet!
SRL790
  • 1954 350
Re: Cam Cover
« Reply #3 on: September 19, 2007, 09:51:19 pm »
Better check the oil level.  There's probably none left!
Andy Wiltshire
