Hey Tanks!
I had to drill the footpeg "barrel", to fit the mount stud assy, and I DID notice the lack of threads, (plus I have a muffler bracket there, is it's short.
I'm gonna, when it all said and done, RED locktite it, (red is stronger than blue. I usually use red on places where it's NEVER coming off, like sprocket mounting bolts.
(just heat up the bolt with a torch or heat gun and it comes right off).
The footpeg mounting "bar" is at a upwards angle and is extended out almost to the max??. I may need to make up a longer bar.
I never got to the fender, maybe tonight, but I'll take a close look at it.
I AM having problem with the toe in.
The instructions don't specify the string height.
I have mine at about 2" off the ground.
I had a........... well, a heck of a time.
I set, adjust, reset the string.
Presently I have a ratchet strap keeping the back IN, and I been adjusting the front mount. I spent 2 hours and really got no where.
Tonight, I think I'll do what I did on my Dnepr. I clamped a pipe, (this time I'll use a board), to the wheels, it makes measuring easier, (in my humble opinion).
I figure if I measure right at the front of the bike wheel, 1/8" toe should be a good start.
Stay tuned to, "Joe goes to 3 wheels"!
Joe
What!
It didn't work? Get me the BIG hammer!
