08 AVL DeLuxe
February 11, 2016, 09:18:59 am
Author Topic: Kick Start??  (Read 1098 times)
daywit
Kick Start??
« on: March 13, 2009, 03:16:18 am »
Why is it that the new C5 does NOT come with a kick start but the G5 does?  They both have the same engines.  It seems that since they are not putting it on both models then they would have put it on the C5 because it is more "retro".  Anyone got any ideas or answers.  THANKS.
Royal.Oilfield
Re: Kick Start??
« Reply #1 on: March 13, 2009, 07:26:23 am »
Hi daywit,
this was already brought up several times as for example
in this thread >http://www.enfieldmotorcycles.com/forum/index.php/topic,3176.0.html<
Kind regards
daywit
Re: Kick Start??
« Reply #2 on: March 13, 2009, 08:37:20 am »
Thanks for the reply.  Don't think I would have ever known where to look without the link.  Appreciate you taking the time.
Royal.Oilfield
Re: Kick Start??
« Reply #3 on: March 13, 2009, 09:09:22 am »
There's an easy way to find out yourself by using the Search function which is implemented in all forums.
Here you can find it in the upper left hand corner.
The yellow incircled area in the attached pic.
That's what I do first when searching for info on certain issues to find out whether this might have been discussed before.
Kind regards
