Hello guys, I've been away for a while from both this forum and my bike - I'm in the final year of my Uni course so have had LOADS of work to be doing. This coupled with certain events meaning that I've now lost the use of the garage that I had has left my enfield in the street, which has certain disadvantages from the point of view of working on it - i.e. unless the weather is semi warm you freeze instantly on touching metal! It has also meant that unfortunately the little rust gremlins have set to work on my 6month old aftermarket silencer too amongst other parts...:-(
Anyway sob story over! Upshot is that it's been nicer recently weather wise and the council have all but stopped gritting the roads, which coupled with the fact that I'm now in a lul period before exams has meant that I've had the time PLUS inclination to actually do a bit of work! Amongst other more mundane general servicing things I've finally been able to fit my Hagon Shocks which I got over 6months ago - more on that to follow though!
Finally down to my question, my primary chain needs adjusting - which obviously requires removal of the chaincase. I need to remove the footpegs too as they impede removal of the chaincase, but the nuts holding the pegs on on both sizes dont seem to engage the threads. They turn easily enough, but they move nowhere. I got a caution on my MOT because my pegs were 'loose' - which was caused by the nuts not being able to be tightened fully. I however asked the guy if he'd like to give it a try getting them to come off, and after 5mins of trying he couldn't budge them so passed me! He reconed the only way to fix the problem was to take a dremil to the bolts and replace the whole lot. Just wondering if there's any other wee tricks o' the trade out there to remove these nuts?
Cheers, Stu
P.S. Sorry for the mini essay, but I thought I had to justify being away for so long! But with a big trip in planning for this summer I'll probably be on here quite a lot more in the near future!
