Will, I think maybe your misunderstanding the electrics. A 12 V bulb that is rated at, say 5 watts, will only draw as much current as it needs to operate. In other words, you can connect it you normal 14 AH motorcycle battery or you could connect it to your car battery that has umteen zillion amps. It will only draw what it needs. Now up the voltage and powee, it's a goner. Voltage is the driving force and current is doing the work.
Here's a link for Ohms Law. http://en.wikipedia.org/wiki/Ohms_law
The two batteries are fine, although unneeded for what he described, unless he hooks them in series. Then all is lost. 24 VDC.
