Bike Crash (June 1st, 2009) - 3
May 05, 2016, 07:28:05 am
Author Topic: UCE - twin spark?  (Read 1287 times)
UCE - twin spark?
« on: February 18, 2009, 04:35:34 pm »
Does the UCE G5 and C5 motor run with one spark plug or (as is the case with the Thunderbird model) the twinspark version?
This article is an interesting read:  http://www.royalenfield.com/company/news/therealitybullet.aspx
t120rbullet
Re: UCE - twin spark?
« Reply #1 on: February 18, 2009, 05:15:32 pm »
The G-5 and C-5 will have 1 plug
The home market TwinSpark had 2.
« Reply #2 on: February 18, 2009, 05:37:19 pm »
A twin plug system can be very effective in certain combustion chambers.
Essentially, it is a "band aid" for a chamber that is having flame travel issues.
This is common on hemi engines with high compression piston-domes which divide the chamber. Or on other chambers with excessive flame travel or impediments, or insufficient "squish" area.
It can help an older engine design remain viable and gain some power with less emissions, when there is a need to keep the engine in production.
I'm not quite sure why anyone would design a modern chamber which needed twin plugs to work correctly, when it is quite easily accomplished with a single plug design if you do it right.
« Reply #3 on: February 18, 2009, 05:44:50 pm »
 I had my old R80 BMW dual plugged, it gave me a bit more power and upped  the gas mileage by quite a bit.
t120rbullet
« Reply #4 on: February 18, 2009, 06:58:30 pm »
It was explained to me that it was done to meet Indian emission standards without using a cat converter.
