So, yesterday I HAD to get out for a ride, (at least on the road, thank God for my KTM and XR off road bikes for year @ riding or I'd go crazy)!
I was impressed. The Military fired after a few kicks with the decompression lever pulled and then the real thing!(it had been sitting since my Xmas day ride on the ice).
So off I go, who cares if it gets muddy, that's what car washes are for!
I had put a 1 tooth larger gear on the front, (to pull the side car, when I get it), a Harley 1200 slip on muffler, (cuz my son took his off), opened the bottom of the green air box and made a filter to breath easier.
I put the engine breather hose hooked to the air box.
I went through town, a few country roads, then this 3 mile hill.
Well, me being me I kept twisting the throttle 50mph is top speed.
The bike was purring along like a tiger, all was good!
About half way up, I smelled oil??
"Man that car up front of me was have a MAJOR oil leak.
I crest the hill and at the stop light, the bike won't idle?
Crank up the idle screw, (must be water in tank, (wishful thinking).
I pull over a bit up the road to decide where to head next, and look down-OIL EVERYWHERE!
Out the bottom of the air box, out the valve adjustment cover!
I shut 'er down and start looking.
Then it hit me!
The motor only has 550 miles on it, I got "throttle heavy", this is blow by
What a bone head!
I check the oil, OK still good, let's just take it easy and head home.
25 miles later, I pull into the garage, (pulled the door off the hinge! Hit the door with the crash bar)!
"Yep, 45 years of riding, and I can't even pull the bike in, (who put that door there)!??
No oil dripping, oil in the crank case, I guess it's OK, (what a Maroon)!
So, the question of the day is...............................................
With everyone changing out the air box for the cone or pancake filters, (I didn't like how the cone looked on my military), what are YOU doing with your crank case vent hose???
I way thinking of getting a small breather filter I saw and running it to the back of the engine, or leave it breath in the box, (realizing that now 45mph is tops with the bigger sprocket!
Ideas?
Thanks,'
Joe
Sometimes my brain is a brick!
