Hey guys,
Finally, I got my LB500 on Wednesday. First of all, thanks to all my fellow forumers at Enfield motorcycles for helping and guiding me during the decision making and the purchasing stages. The dealer called me to the dealership at 5pm for delivery. I was there at 430PM. Finally the delivery happens at 7PM. Phew! In the interim, I got a crash guard fitted, checked the oil level and took the bike for a test ride to check how the bike was. The LB500 rode well but didn't pull as hard as the test bike that I rode a few weeks ago. When I quizzed the showroom guys about this, they said as I was riding with less than one fourth throttle, I wasn't feeling the power and torque. I was satisfied with this reply as I was using just one fourth throttle in all gears and not taking it past 50 in top gear. I filled in nine litres of fuel to supplement the showroom guys' one litre of fuel.
Then, I took delivery with the odo reading 10 and rode down to Gaadi(vehicle
) Ganesha temple for Pooja. I was a little tired as the bike was pretty heavy in traffic. My only grouse with the LB500 was the high clatter and vibrations at idle although the engine sounded good and felt smooth once the bike was doing around 40-50. Finally when I got home, the bike had covered 35 on the odo. I'm not commuting yet, to my office in E-city as I don't want the bike subjected to peak hour Hosur road traffic.
Next day, I took the bike out for a spin after work. I covered around 50kms after 7 at night. I took the Outer Ring Road near Hebbal Lake and switched off the bike at the traffic signals. I rode at a speed of 50, never exceeding 55 in top gear and I also slowed down now and then and then accelerated gently to make sure that the engine saw different rpm levels in different gears. Overall I felt happy although I felt that the power and torque was less. Also the engine got heated up pretty fast at idle and I couldn't keep my hand on the timing chest for more than two seconds as it was pretty hot. When I returned home and observed the engine for oil leaks, etc, I found a few drops of oil around the the breather pipe. I checked the oil level and found it to be almost full. So, not too surprising as the bike was depositing the extra oil to the catch can. But, as the breather pipe wasn't fitting snug enough, a few drops oil was being let out. So, I set that right. The odo read 85.
On Friday night, I took off and rode towards the Bangalore International Airport( awesome smooth tarmac) Kept the speeds to less than 55-60 and varied the speeds in all gears with gentle acceleration and deceleration. I also gave breaks every 40-45 minutes and let the bike cool for ten odd minutes before starting off. Finally came back home late. the odo read 163.
I was very happy with the stability and poise. I was unhappy with the somewhat sluggish performance and the diesel autorickshaw-like clatter at idle.
Finally Saturday arrived. After a late brunch, I went to JC road and bought two AGV MPA lids(one for my brother) from Megha Enterprises. I took a circuitous route to avoid traffic to keep engine temperature low. Then, i rode down to Cramster for a jacket and gloves. It was closed as the Cramster guys were off to the Rider Mania. Then, I took off to get some mileage in. Back on the new airport road. This time, I pushed it to sixty where I found that the bike loved it. I had found it's sweet spot. Finally, after passing the airport, I turned around and rode home. Was pulled over by cops for overspeeding. When I asked for a print out, the cops sheepishly showed a fifty one. So they couldn't fine me as I was under the 60 K's speed limit. Just before reaching home, I tanked up. 11.12 litres of fuel went in to fill the 14.5 litre tank. The speedo read 260. I was amazed. I had covered 260 clicks in approximately less than 6.5 liters. So that made for a mileage of 40+ on a 500cc. I wasn't happy, not happy at all. Was my baby running to lean? Got home and checked the silencer bend pipe for blueing. No signs of it. Touched the timing chest. Engine was pretty hot.
Now, this is leaving me all worried. Could the lack of pick up and hot engine be due to the lean mixture? That said, cold starting is not too much of a hassle with the bike needing choke to start and some warming up. But, the engine has a minor misfire when I am decelerating using gentle engine braking. This happens, even when the engine is warm. So, is my bike running lean and does that explain the lack of grunt at lower rpms? Or is the high gas mileage due to the fact that I'm riding gently without straining the engine? I personally think the misfiring is due to a lean mixture or the timing may be off as the engine is getting run-in. If it is the latter, that explains the lack of grunt and also the misfire. Or it could also be a combination of both which could explain the factor of high mileage as well. Or is it something else? Bullet gurus, please chip in with your know-how. I'm a little anxious. I just don't want the engine to run lean during the very critical running-in phase. Please HELP!
Also, the bike vibrates quite a bit at idle and the clatter is high/noisy during idle, when the engine is warm. Will that reduce and do bullets, especially AVL500s become smoother after the first service? Please advise as I have no clue about all this and what to expect aftre the first service as I am a newbie bulleteer.
Meanwhile, I will check the spark plug tomorrow morning. Also, I plan to cover another laidback 120 kilometres each day on traffic free/ fast moving city roads tomorrow and on Republic day. So, that means, first service on Tuesday or Wednesday. Till then, I can only hope that my LB500 isn't running lean. Tomorrow, I will ride down to Gurunandan's( a great bullet mech) garage and pick up a Pete Snidal manual. But, Nandan himself advised me against touching the engine as it will void warranty. So, I have to keep off that temptation.
Also, please excuse the lack of pics folks. My digicam is on vacation somewhere in Kasargod, Kerala with a dear friend of mine. I will post pics after the first service. Will keep you guys updated. Sorry for the long post.
Cheers,
Jay
