The Green Marauder
46 Guests, 3 Users
Ice, gizzo, JohnDL
April 29, 2016, 03:14:16 am
Author Topic: The 612 conversion kit  (Read 11890 times)
HMR
Re: The 612 conversion kit
« Reply #30 on: September 18, 2007, 02:16:26 am »
Here is my pride and joy, a 2003 Bullet Military:
Pete.
Nice bike.
Is the carb-filter assembly attached only to the intake port? I use a Mikuni 32 mm with a Pipercross pod type filter and have had to make a bracket bolted to the rear tank mount to support the heavier carb  as the flange as well as the rubber manifold cracked with the weight nd vibrations.
Thanks
HMR
Peter
« Reply #31 on: September 18, 2007, 04:59:10 pm »
I have an Amal 30mm and an alloy manifold.
No other attachments and no problems so far.
(The second picture shows an in-line spin-on oil filter, in case someone notices)
Peter
« Last Edit: September 18, 2007, 05:04:50 pm by Peter »
