homebrew
57 Guests, 6 Users (1 Hidden)
flyman, Dodd, The Old Coot, kodai, Tarnand
May 30, 2016, 11:28:12 am
Author Topic: Figured Front Brake Light Switch  (Read 1611 times)
erob123
« on: January 16, 2009, 08:42:40 am »
Having trouble with Brake Light on all the time.  Pulled Front Brake Light switch and beware the little plunger (plastic) after a while tends to get bent.  I flipped 180 degrees and installed works good now.  For how long don't know.  FYI.   Probably will order new.  Think it's caused by crappy finish on brake handle where it hits.  Trying to think of a way to improve handle without removing material.  Like adding piece of shim stock or metal tape to surface.  Got any ideas?  Might machine slot and add slick metal insert.
My 2008 B500 Military running great at 3200 miles.  Thinking on planning the MVPA 3500 Lincoln run in June.  So long thanks for the help.  Eric
mrunderhill1975a
Re: Figured Front Brake Light Switch
« Reply #1 on: January 16, 2009, 12:43:39 pm »
My switch was damaged after I strapped ithe bike down in the back of my pickup.  One of my attaching "hold-down" straps was attached to the handlebars such that it pressed on the brake light switch bending it somewhat.  Have you trailered your bike recently?
t120rbullet
« Reply #2 on: January 16, 2009, 04:12:18 pm »
CMW has the switch on sale in the Clearance Center right now,
http://store.royalenfieldusa.com/clearance/front-brake-light-switch
Might be a good time to stock up at that price.
Spitting Bull
« Reply #3 on: January 20, 2009, 05:29:12 pm »
Absolutely!  at that price, you can't go wrong.
Tom
500KsGerry
  • Remember when decency wasn't a option?
« Reply #4 on: February 13, 2009, 05:05:36 am »
a tiny dab of white lithium grease cured  this  prob on mine or was it De-ox.
« Last Edit: February 13, 2009, 05:07:29 am by 500KsGerry »
Modified 2001 Royal Enfield bullet 500
The Garbone
  • Shade Tree
  • User Complaints: 22
« Reply #5 on: February 13, 2009, 06:48:15 am »
Cool,  mine is a little loose so I ordered 2,  just because they are $2...
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
FiRE Comms
  • '11 C5
« Reply #6 on: April 21, 2014, 07:08:38 pm »
reviving an old topic but having an issue...  brake light flickers (sometimes) and sometimes does not light when using front brake...  replace the switch?
Chris
baird4444
« Reply #7 on: April 21, 2014, 07:55:23 pm »
and check for corrosion on bulb, and check ground...
'My dear you are ugly,
 - Winston Churchill
FiRE Comms
  • '11 C5
« Reply #8 on: April 21, 2014, 07:57:43 pm »
brand new led fixture, no more bird house...  and it's only when the front brake is used....  I wasn't sure if there was a "fix" for the switch or if it was a replacement item...
Chris
baird4444
« Reply #9 on: April 21, 2014, 09:32:31 pm »
if you have any electrikle contact cleaner you could spray
some up into the switch. Maybe that little nub is worn
or bent over.....
 - Winston Churchill
