This might hekp you.
Yes, thank you.
That shows the older 1-piece unit, but it clearly does show that they might still be using a full wave bridge, because their older ones used a full wave bridge. So they certainly could still be using it, and it would be the appropriate choice, as we would expect it to be.
However, I'm still somewhat confused based on what Kevin wrote about the unit's operations in his technical brief about troubleshooting the charging system.
Those comments seem to indicate something else, which wastes half the wave, and that seems to me like what a half wave rectifier would do. .
We will get to the bottom of it, when we see Jeri's scope results.
If this was all just a wild goose chase, then, oh well.
If not, we have something which we should be able to improve upon.
