On my '06 Electra, the high beam indicator quit working. I have checked/replaced the bulb in the speedometer head and verified that the wiring from the connector to the bulb works. The high beam works with the switch just fine, it's just the indicator. The wiring diagram in the Snidal manual (electronic version) seems to be for the Classic not the Electra, and even there I couldn't find the indicator bulb.
Does anyone know if there is a separate contact for the indicator bulb in the handlebar switch? or does it trigger off the same line that feeds the high beam itself? I haven't taken the switch apart yet, as I wanted to see if it were necessary given that the high beam does work.
Any help would be greatly appreciated.
Thanks,
Brian
