I have a 2006 Electra. While I had my spark plug out to check it, I decided to spray a
little fogging oil inside....with the spark plug still out I pushed the Kick Start pedal with my
hand, thinking I was lubricating the cylinder & piston until it reached the final (TDC) position.
The pedal moved normally until it reached the bottom position.
However, now my kick start pedal will travel about 4" from the top position with no resistance until it stops. It is not moving the piston at all. I just have about 4" of play in the pedal and it stops.
Put the spark plug back in (disconnected) and no difference.
I didn't want to try the electric start fearing I might damage or further damage something.
Any ideas?
Thanks in advance.
