I put the auto-advance unit back in, complete with snappier springs. It is interesting just how an engine's characteristics can change upon a slight alteration of a minor but critical part.
Yup, those new springs were too snappy. They drove the auto advance actuation threshold up the rev range, making the bike retarded and intractable at low engine speeds. Oh, and the engine still hiccuped and faltered once in a while, as before.
So I put the old springs back.
Unbending the auto advance plate, as per my last post, did slightly extend the range of auto advance available and my engine is now definitely a bit sweeter at all speeds. I had previously been vexed a bit by ignition timing issues: a static advance setting for easy starting stifled performance at higher revs.
BTW, if you want to check your auto advance mechanism but don't have the extractor tool, you can, with care, dismantle all the movable bits off the back plate without pulling it off the distributor shaft. If the central retaining allen bolt is removed, the movable bits are only then being held in place by the advance control springs. These can be unhooked and re-hooked with care.
