Hello from Snowy Pa.!
Your post is a little confusing,
but I think I kinda know what your talking about.
The motor is hard to start, mostly warm, when you come to an idle, it dies?
So that means, either the idle speed is too low, the air screw for the pilot circuit is in too far, (too lean), the pilot jet is too small, or you got an air restriction.
Also, now that I think of it, it could be too rich................................
So let's start at the beginning. You've got GOOD gas, (no chance of it being old,contaminated with water, etc?
Smell it, if it smells like varnish is yellow, toss it, and get new stuff.
Next pull your spark plug. The electrode should be a nice tan, if it's white- too lean mixture, black and sooty, too rich.
If it tan, I'd try turning up your idle screw .
If it's white, turn OUT your mixture screw, (2 1/2 turns is max. more than that you need a step larger pilot jet).
If it's black, check your air filter, (air restriction is what we're looking for)
Your float height might be too high, choke stuck on, SOMETHING that causing too much fuel to enter the engine.
I'd take a look at your valve adjustment also, a tight valve will make it hard to start/ run crappy.
If all looks good.............. It's a new scoot, run it back to your dealer.
Might be timing, compression, but let's not panic!
Start with the easy stuff.Good luck and keep us posted!
Joe
I ride, therefore I am!
