" Mike, I am working on installing a brand new '06 ES motor (minus ES) w/ 5spd replacing my '03 motor w/ 4spd that died. I will have to re-tune the carb for this new motor. So right now I can't be much help, sorry! Have you tried a different clip position yet? Also, make sure your float height is correct; those float bowls hang up sometimes when you remove them and if your not careful you can disturb the float or needle carriage. What is your exhaust note like after the modification of your tank killer? - Blltrdr "
first off, what happened to the 03?? When it's time to get rid of the spares that you can't use on the 06 give me a shout. I'm collecting spares for the inevitable....
What is the correct float height??
As far as the clip, I had such a hard time compressing that LONG spring when I first installed that I've been hesitant to fight it again. As a matter of fact; I clipped 1/2 an inch off of it just so I could get it all compressed to get the top back on. To tell you the truth, I think I'm so rich that I'm still taking the large steps with the jets, then I'll get down to the baby step fine tuning with the needle.
Exhaust note - Not that " tinnie" sound that I've heard from others.... lo and mellow at idle. I've also cut off all but about 2 inches of the pipe at the end. I've thought about cutting it off flush and then taking a holesaw and opening it up a little more. This should give me a little better breathing and look WAY COOL. So long as I'm working on the jetting, now is the time. It gets to a loud deep roar when I grab some throttle and sounds even better when I let off. Last Sept. was the first I've ever let anyone else ride it and I gotta tell ya; it sure sounded good heading off down the highway.
- Mike
