All electronic ignition models should obtain the new ignition module, as the first preventive step.
Here is a service bulletin from the factory that I just pulled off the web, which circulated a couple of years ago:
16th May 2006
TIPS FOR FIELD SOLUTION FOR SPRAG CLUTCH FAILURE IN ELECTRICAL START
VEHICLES
I. Steps to follow when metallic noise & slippage occurs in the
Sprag clutch
a) Dismantle the Starter Motor, Chain case inner and the Drive
cover.
b) Remove the idler gear , sprag clutch drive & driven gears
assembly and the shims. Keep a track of the number of shims that were
used.
c) Separate the Drive and Driven Gears. Inspect the thrust washer,
for any rough surface, bent or disfigured condition.
d) Inspect the sprag carefully for: Damage to the sprag ends
(individual bearings), damaged / broken/ sticky movement inside the
sprag bearing cage.
e) Carerefully look for deep dent or impression on Sprag track in
the sprag clutch drive and driven gears.
f) If there are deep dent marks in the sprag tracks either in the
gear inner OR the outer, then replace the entire assembly (part No.
560042/a) with a new set after carefully cleaning and lubricating the
same.
(the sprag assy should be cleaned without dismantling
g) Carefully also inspect the following:
- Spindle on the drive cover for tightness (by hand), check oil
flow through spindle with oil can. If the oil does not flow through
the spindle, ensure this is not due to a block. The spindle should
not be free to rotate when pressed into the drive cover.
- Check the bushes in the chain case inner and the drive cover for
any cracks or recession into the housing. (bush top must be level
with the housing boss)
h) Reassemble the sprag clutch assy in the Chain case inner and take
care to reassemble the shim washers, gasket, drive cover. Check the
assembly is having the correct end float of 0.25 to 0.30mm after
tightening the drive cover screws fully. (Manual is incorrect in
stating 1.5mm.) The gears must rotate freely and very minute end
float must be felt. Refit the assembly onto the vehicle.
II. Steps to follow when Sprag Clutch / Gears are BROKEN
Note: One of the prime causes for the gears and/or the sprag to break
is the engine backfiring and/or the bushings in the chain case inner
have dislocated or damaged.
Dismantle the chain case assembly and the sprag gear assembly as
above.
Inspect the Bush in the chain case inner and in the drive cover
Inspect oil flow through the spindle.
Check for proper tightness of the spindle in the cover.
In classic (Cast iron engines) Check thoroughly if the ignition
timing is
advanced beyond 0.8mm BTDC (due to incorrect settings OR due to the
advance fly weight mechanism in the distributor is stuck in open
position) The advance retard weight could get stuck due to its
catching on the rear side of the condenser OR weak springs OR bent
posts OR the locating tab getting stuck inside the groove of the
flyweight.
In Lean Burn engines, if the sprag or gears are broken, please ensure
that the New TCI Part No. 147100/c is fitted to take care of a
backfiring caused from premature ignition.
If the sprag or the gears are breaking for the first time in a bike,
check the above and replace.
If the sprag is failing for a second time in the same engine, it is
best to check the above and also replace the chain case inner
assembly as appropriate to the bike to avoid any further failure.
