So, If you been following my continuing sage of, "Joe's bike breaks when he needs it most' on this station, you know that my sprag went south.
I called the dealer, he's got parts coming, but I figure I'll take it apart, order parts and keep his for a spare for me or???
For those who are afraid to do it, relax, it's as hard as a tune up!
Here's all the tools I used for the disassembly,
a big 2 finger puller a harmonic balance puller
32,22,18,14,13,11,10 mm sockets
7/16", 7/8" sockets
4mm, 5mm Allen head sockets
3/8" ratchet, with 12" extension
2 flat screw drivers
Crescent wrench
Rubber hammer
1/2" impact driver gun, (you can use a 1/2" ratchet instead. Nothing was THAT tight)
took @ 1 hour to get it in a million pieces. That was with my dog coming in for a "Quick! Pet me Joe, I'm so lonely" 100 times, breaks to watch the NFL game on the tube, (what kind of a work shop would it be without a T.V)?
Now, for the weird thing I found-
I was expecting to see one of the paws broken, a bent something, something broken!
There was zip!
The paws were all at the same angle but 2.That were say, at a 45 degree angle, instead of a 30 degree.
the sprag was just jammed?
Now, the motor was chugging away at low rpm, (cold) when it happened, that may explain why.
I tried to rotate it in every why I could to engage the paws, but nope.
I went "Postal" on it and banged it flat on the work bench, then took a small screw driver and worked the paws.
Finally the 2 fell out. I reinstalled them and...
It freed up!
Put that part together and it's working fine?
Intresting.
I think because of the location, (up high in the primary cover), that it was dry and that caused it to hang up, OR
The 10-40 oil was thick causing things to slide slowly and hang up.
Me thinks when I re assemble it, (with a new sprag, I'm not taking any chances), I'm gonna switch to synthetic oil, (Motol makes a 0-40 bike oil), or trans fluid, (I use that in my off road bikes when it gets cold. It makes the clutches "grabby" but shifts well no matter how cold. Plus I think I'll raise the oil level up.
I look at it this way, I had to do only 1-2 more steps cuz I wanted to swap out the front sprocket to a smaller one, (when I get the side car).
Your thoughts?
Joe
I ride, therefore I am!
