Hey Scotty!
Try this to make you beauty fire quicker.
If it's got stock jetting, zip out the idle mixture screw 3/4 turn, raise your needle 1 clip, (put the "E" clip 1 lower to the point).
Run a grade lighter oil, to make it spin easier.
A motor needs more fuel when it's ccccooooolllllddd to fire, and run good.
Pull the compression release in and with the key off, kick 4-5 times to get everything moving, (remember the pictures of the WW2 ground mechanics turning the props on the planes by hand to get everything spinning)?
Think of it as a "pleasant warming experience" rather than a !#%$&^*&&^%%$$@%!!! in the arse!
I also don't put all my "layers on" until I get my scoot fired. This way it warms up whilst I'm dressing, and I don't work up a sweat going through the drill!
Just an old guys thoughts.
Joe
I ride, therefore I am!
