So I did the BIG 300 mile service on my '09 Military Saturday morning.
I had already dumped the oils at 100 miles, so it was just a re torque and adjustments.
Nothing weird, valves were good, a few bolts slightly loose, etc.
I had bought a service manual for the new motor, so I was following that.
I had a '04 bullet with the old style cast iron cylinder a few years ago, so I had an idea of what to look for.
So, I read in the manual, loosen the clutch cable, (I had it removed to lube up), R/R the cover, loosen the locking nut, turn the adjusting screw until SLIGHT pressure and tighten up the locking nut.
I could be wrong, but I swore on the older 5 speeds, you ran the adjusting screw in until contact and back it our 1/4 of a turn.
Funny, that's what this one was out by-1/4 turn.
SO, I split the difference-1/8 turn. Put the cable back on, got the slack out and took 'er for a ride. Seems OK?
So, has the drugs from my youth finally got to the few brain cells I had left or what?
What is the CORRECT adjustment for the adjusting rod??
Joe
You can teach old dogs new trick, it's just that they can't remember it for long.
