Guys is this topic dead, because I am a fighter and I can continue the insanity for post points, and other selfish reasons. OH I forgot to mention rehabs for quitters and I an't no quitter.
But I still need the best advise on the possible mods for performance, which I think ACE was nice enough to give his input. carb, pipe and filter
What is the best set up of carb pipe and filter?? any suggestions?
I would suggest looking at the aftermarket exhausts from CMW and seeing what you like. Remember the AVL takes a different pipe than the Iron Bullet, so you have to be clear about what items you are looking at. I think CMW refers to the AVL as the Electra in their catalog.
That mod will do away with the PAV system, so that will have to be yanked off, and the holes plugged.
While you're doing hoses, you may as well re-route the breather properly, so that you don't spew oil out of it.
For the carb, alot of people like the flatslide Keihin copy carb that CMW sells. It seems to be a good one. I like the flatslide Mikuni. In any case, don't fit any carb bigger than 32mm, or 34mm at max. 32mm is plenty fine for the top end, and it idles better than the 34mm does on the Bullet.
You'll have to do a full jetting job and tuning on whatever carb you get, so set aside a weekend for that. It's a bit time consuming to get jetting right, and can be frustrating in some cases. Translate that to mean it's a pain in the ass to get out all the flat spots, coughs, or idle problems, and get good mixture distribution across the rpm range for good power and fuel mileage. Definitely learn how to do plug chop readings.
K&N or S&B filters that fit the carb you select are available.
The 18 tooth output sprocket on the gearbox output shaft(front drive chain sprocket) is a good mod for it.
Gives you about 4mph more cruising speed at normal rpms, without sacrificing much in acceleration.
That should do you.
Do it AFTER break-in. You can't use any of the performance these mods will provide during the break-in period anyway.
