Here ya go, guy!
http://www.oldbritts.com/amal_tun.htmlRemember these things about Amals.
They warp extremely easily at the flange where they mount to the head, so NEVER over-tighten them.
If you do overtighten them, you'll warp the body and you'll never get it to run right, unless you sleeve and re-true the body.
The slide wears out in a short time, sometimes like 5000 miles. When the slide is worn, it passes air past the slide when it's supposed to be closed, and the idle is always whacky after that. You can get new slides, or get them plated for durability.
Little bits of dirt can clog the idle circuit, so keep it clean.
If you get disgusted after a while, get a Mikuni.
The Amal design is okay, but it is made out of junk pot metal and doesn't wear well.
