old 11989 a
May 05, 2016, 07:29:31 am
Author Topic: Ok What the heck happened?  (Read 2357 times)
Charro
« on: August 21, 2007, 12:13:55 pm »
Was out of town for a month, before leaving I put the RE on a battery tender, shut off fuel, and thought I put it on TDC.
Well yesterday I went to start it, blew enough smoke out the pipe to kill every skeeter in the county. Blew oil out the duckbill breather all over the floor, what a mess. Rode it down the road, to clear it up stopped smoking, and ran fine. Checked oil level, was about  half way down the stick.
So what happend , wetsump? What do I do now? always thought that TDC was when the altmeter needle was on top. Maybe I was on BDC?
Good news is it started first kick.
Andy
« Last Edit: August 21, 2007, 04:01:55 pm by Charro »
2014 Royal Enfield C5
2004 Triumph Sprint RS
2004 Triumph Speed Four
2001 Triumph Bonneville
2006 Triumph Scrambler
1998 Triumph Speed Triple
1998 Triumph Daytona
2012 Ural Gear Up
"Tell me what kind of horse you want to ride. I'll tell you what kind of rider you are." (Old Mexican proverb)
RagMan
  • Bulleteer, Uralist &
Re: Ok What the heck happened?
« Reply #1 on: August 21, 2007, 01:20:00 pm »
Kind of alarming thing to happen - I ain't had that happen. It sometimes blows a bit of smoke, but when I remember to TDC it parked, it doesn't.
aka Indiana Bulleteer.
Jefferson County, WA
HRAB
  • I should really edit this
« Reply #2 on: August 21, 2007, 02:42:45 pm »
If the engine smoked on startup, but then ran fine without smokeing it probably was wet sumping. The worm gear seal is often the cause of start up smoke.
BMWMOA www.bmwmoa.com
74 Honda XL350 'Scoot'
81 Honda CB650C
00 Honda ST1100 'Large Marge'
Spitting Bull
« Reply #3 on: August 21, 2007, 04:51:10 pm »
Easy solution - get ready to ride, sit on the bike, start it up, ride away, don't look behind for the first 30 seconds.  8)
The ammeter is in the central position nearly all of the time.  When you feel compression through the kickstart and see the ammeter needle move to the left you are coming up to top dead centre on the compression stroke.  That's where you need to leave the piston.  (There's another top dead centre at the end of the exhaust stroke.  That'll do too, but the compression one is easier to find.)
Tom
dewjantim
« Reply #4 on: August 22, 2007, 02:00:43 pm »
If my bike sits very long it does the same thing. Usually I go out every week or so in the winter and give it a few kicks and maybe start it. If it sits for a couple of months, just drain the oil from the engine before starting. I think it is the front drain bolt on the bottom of the engine. I have 5 more bikes to keep up with so I am not sure of its location until I crawl under there and look....Dew.
Andy
Charro
« Reply #5 on: August 22, 2007, 04:25:27 pm »
Update, went out today kicked ur over, started first kick. No smoke, no oil out the duckbill, no drama, just a smooth tickover.
Thanks for the help, guess it was wet sumping.
Andy
2012 Ural Gear Up
