Correction: It wasn't Edward Turner who wanted a 270 crank in his Speed Twin.
It was another famous and a Australian motorcycle designer Phil Irving who at one time at least was the head engineer at Vincent. He began criticizing Turner"s 360 crank design as early as 1944 and saw the 76 degree crank as a much better design. Ok, bit of a difference between a 90 and a 76, but not enough to be arguing over. Pretty much the same superior primary balance results with either and much better than the 360. This isn't a case of RE being monkey see, monkey do. It's using real engineering to result in a superior product. And It's not like RE and Triumph are chasing down any particular exhaust note
